StingerGT68
- Jan 29, 2018
The clear wraps that people are having installed on cars.If I may ask: what is a ‘clear bra’??
I recommend using a hair dryer. I removed my back Kia badge with fishing line and the front with dental floss. I had a couple scratches on the back and no scratches on the front. So you may want to use dental floss for a while and when you stop making process switch to fishing line.
Thanks I’ll need some rubber squeegee things then.. not sure how else to get between paint and badge to pry..That's because there is double side tape in between the pins, where the dental floss cannot get to and cut through. If you have the sides already off, pry it off carefully.
How do you not scratch the paint ?Just did mine today I used a old credit card I had laying around.
Where did you get those scrapers?I just did my front and back badge replacement this weekend. I started with heat and dental floss, but that was not going well.
In the end I ended up getting 10 lb fishing line and plastic spreaders to help pry once most of the adhesive was cut. I placed painters tape all around the badges as well. When you are sliding the fishing line back and forth pull towards you to minimize the friction on the car. I also soaked the area with goo gone before starting.
Getting the left over adhesive off was not fun. Lots of goo gone and heat did the trick. I just used my thumb to roll it off. It was slow but no scratches.
I just had very good luck using nylon lockout wedges photos.app.goo.gl/BfkKrdkhWay99rmi6
They are cheap, they look like this amazon.com/iit-Emergency-Door-Lockout-Wedge/dp/B07H4X7P8S/ref=sr_1_46?ie=UTF8&qid=1538580281&sr=8-46&keywords=lockout+wedge
Buy it in addition to this amazon.com/Wedge-BUZIFU-Pieces-Elevating-Windows/dp/B07C3P2B6T and amazon.com/Quick-Max-Long-Reach-Tool/dp/B019V1TLJY and be the hero to your friends never having to pay a locksmith, Not that we could lock our keys in if we tried.
