Dochidalgo
I don’t like big rear bars on RWD cars. Stinger seems to turn well too. Bigger rear bar Limits rear traction too. I’d go bigger front. Bigger front tends to hold everything straight so rears hook up better. I think Eibach kit is fine I’d just like to see a damper that goes with that kit . It’s too bad we can’t dial in bump with a set of gas dampers. My ideal is slightly firmer rear shock settings Little more compression from damper and near to oem size sway bars.
@CaliSting, and fellow members with Eibach Pro Kit installed........Kia claims that the GT2 has installed "high performance dampers". So do you think that replacing the stock springs with progressive ones, like Eibach's Pro Kit would be enough in order to get more maneuverability and less floating behavior????. I'm very disappointed with the suspension performance (my former 2016 Nissan Maxima SR made me feel in control)....Thanks
